Zum Hauptinhalt wechseln
Sony Vaio VPCCW17FX LCD Screen Replacement
Was du brauchst
  1. Sony Vaio VPCCW17FX LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Slide both latches towards the center of the battery to release.
  3. Sony Vaio VPCCW17FX LCD Screen Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VPCCW17FX LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX LCD Screen Replacement: Schritt 4, Bild 1 von 2 Sony Vaio VPCCW17FX LCD Screen Replacement: Schritt 4, Bild 2 von 2
    • Remove the rubber pads on all four corners of the screen bezel using the spudger.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver.
  5. Sony Vaio VPCCW17FX LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the screen's plastic bezel.
    • You need to use slight pressure to release the clips.
  6. Sony Vaio VPCCW17FX LCD Screen Replacement: Schritt 6, Bild 1 von 2 Sony Vaio VPCCW17FX LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove all four screws (Length: 7.7 mm) using a Phillips #0 screwdriver. Make sure to hold the screen while removing the screws so it doesn't fall.
    • Using your thumb, carefully lower the glass and place it on the keyboard.
    • Do this slowly to avoid damaging the screen.
  7. Sony Vaio VPCCW17FX LCD Screen Replacement: Schritt 7, Bild 1 von 2 Sony Vaio VPCCW17FX LCD Screen Replacement: Schritt 7, Bild 2 von 2
    • Pull off the tape and disconnect the display cable connector by gently sliding up to remove it from its socket.
  8. Sony Vaio VPCCW17FX LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • The screen can now be removed.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Seowon Song
113 Reputation
1 Anleitung geschrieben
Texas Tech, Team S8-G5, Bennett Spring 2017 Mitglied von Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 1,130
