Zum Hauptinhalt wechseln
Sony Vaio VPCCW17FX RAM Replacement
Was du brauchst
  1. Sony Vaio VPCCW17FX RAM Replacement, RAM: Schritt 1, Bild 1 von 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX RAM Replacement: Schritt 2, Bild 1 von 1
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX RAM Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VPCCW17FX RAM Replacement: Schritt 3, Bild 2 von 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX RAM Replacement: Schritt 4, Bild 1 von 2 Sony Vaio VPCCW17FX RAM Replacement: Schritt 4, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) that is covering the RAM.
  5. Sony Vaio VPCCW17FX RAM Replacement: Schritt 5, Bild 1 von 1
    • Lift the black plastic cover to assess the RAM.
  6. Sony Vaio VPCCW17FX RAM Replacement: Schritt 6, Bild 1 von 3 Sony Vaio VPCCW17FX RAM Replacement: Schritt 6, Bild 2 von 3 Sony Vaio VPCCW17FX RAM Replacement: Schritt 6, Bild 3 von 3
    • Apply light, outward pressure to the locks on both sides of the RAM.
    • Rotate the RAM up and slowly pull towards you to remove it.
  7. Sony Vaio VPCCW17FX RAM Replacement: Schritt 7, Bild 1 von 3 Sony Vaio VPCCW17FX RAM Replacement: Schritt 7, Bild 2 von 3 Sony Vaio VPCCW17FX RAM Replacement: Schritt 7, Bild 3 von 3
    • In order to remove the secondary RAM, use the same outward pressure on the locks.
    • Lift and slide out the RAM to remove it from the slot.
Abschluss
Mia Martinez
101 Reputation
1 Anleitung geschrieben
Texas Tech, Team S8-G5, Bennett Spring 2017 Mitglied von Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 1,158
