Zum Hauptinhalt wechseln
Sony Vaio VPCCW17FX Webcam Replacement
Was du brauchst
  1. Sony Vaio VPCCW17FX Webcam Replacement, Webcam: Schritt 1, Bild 1 von 1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Webcam Replacement: Schritt 2, Bild 1 von 1
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Webcam Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VPCCW17FX Webcam Replacement: Schritt 3, Bild 2 von 2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Webcam Replacement: Schritt 4, Bild 1 von 2 Sony Vaio VPCCW17FX Webcam Replacement: Schritt 4, Bild 2 von 2
    • Remove the four rubber circles using the spudger located on each corner of the laptop.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver that are located under each rubber circle.
  5. Sony Vaio VPCCW17FX Webcam Replacement: Schritt 5, Bild 1 von 2 Sony Vaio VPCCW17FX Webcam Replacement: Schritt 5, Bild 2 von 2
    • Slowly peel off the plastic covering around the screen.
    • Place it to the side once it is completely disconnected.
    • You may need to apply slight pressure to release the clips of the covering.
  6. Sony Vaio VPCCW17FX Webcam Replacement: Schritt 6, Bild 1 von 3 Sony Vaio VPCCW17FX Webcam Replacement: Schritt 6, Bild 2 von 3 Sony Vaio VPCCW17FX Webcam Replacement: Schritt 6, Bild 3 von 3
    • Remove the two screws (Length: 7.7 mm) using the Phillips #0 screwdriver that hold the Webcam in place.
    • Gently pull the webcam away from the laptop.
    • Slowly disconnect the two ribbon cable connectors by sliding them towards the wire to disconnect the webcam from the laptop.
Abschluss
Tiffani Beck
219 Reputation
2 Anleitungen geschrieben
Texas Tech, Team S8-G5, Bennett Spring 2017 Mitglied von Texas Tech, Team S8-G5, Bennett Spring 2017
TTU-BENNETT-S17S8G5
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 1,129
