Zum Hauptinhalt wechseln
Sony Vaio VPCEB11FM Audio Card Replacement
Was du brauchst
  1. Sony Vaio VPCEB11FM Audio Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 2, Bild 1 von 1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Audio Card Replacement, RAM: Schritt 4, Bild 1 von 2 Sony Vaio VPCEB11FM Audio Card Replacement, RAM: Schritt 4, Bild 2 von 2
    • Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
    • Once the cover has been loosened, pry the cover with your finger for it to come off.
  5. Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 5, Bild 1 von 3 Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 5, Bild 2 von 3 Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 5, Bild 3 von 3
    • Use your fingers to gently pull the white plastic strip outward on both sides.
    • Once you pull the strip, the strip of RAM will loosen up. Once loose the strip of RAM should lift out.
    • Once done with the top strip of RAM continue for all continuous strips.
  6. Sony Vaio VPCEB11FM Audio Card Replacement, Hard Drive: Schritt 6, Bild 1 von 2 Sony Vaio VPCEB11FM Audio Card Replacement, Hard Drive: Schritt 6, Bild 2 von 2
    • Using the Phillips #01 Screwdriver, remove the two 7mm screws.
  7. Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 7, Bild 1 von 3 Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 7, Bild 2 von 3 Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 7, Bild 3 von 3
    • Use your fingers to pry the cover upward.
    • Unscrew the two 7mm screws.
    • Pull the plastic tab in the direction of the arrow to take out.
  8. Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 8, Bild 1 von 2 Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 8, Bild 2 von 2
    • Lift plug side first.
    • Remove all the way.
  9. Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 9, Bild 1 von 3 Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 9, Bild 2 von 3 Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 9, Bild 3 von 3
    • Skip to next step if accessing other components.
    • Remove the 3mm screws with the Phillips #1 Screwdriver from hard drive bracket.
  10. Sony Vaio VPCEB11FM Audio Card Replacement, Audio Card: Schritt 10, Bild 1 von 3 Sony Vaio VPCEB11FM Audio Card Replacement, Audio Card: Schritt 10, Bild 2 von 3 Sony Vaio VPCEB11FM Audio Card Replacement, Audio Card: Schritt 10, Bild 3 von 3
    • #1 Unscrew the back panel
    • #2 Then work the tool around the sides to release cover. You may need a second tool to help keep your loose corner open.
  11. Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 11, Bild 1 von 3 Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 11, Bild 2 von 3 Sony Vaio VPCEB11FM Audio Card Replacement: Schritt 11, Bild 3 von 3
    • Unscrew the screw with the size of * screw driver
    • Left up the case holder
    • Gently pull the connective cable
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Maxine Filcher
1.153 Reputation
8 Anleitungen geschrieben
UW Tacoma, Team 1-5, Rose Winter 2017 Mitglied von UW Tacoma, Team 1-5, Rose Winter 2017
UWT-ROSE-W17S1G5
4 Mitglieder
16 Anleitungen geschrieben
Ein Kommentar
I appreciate it
Thedeen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 20
Insgesamt: 1,120
