Zum Hauptinhalt wechseln
Sony Vaio VPCEB11FM RAM Replacement
Was du brauchst
  1. Sony Vaio VPCEB11FM RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM RAM Replacement: Schritt 2, Bild 1 von 1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM RAM Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM RAM Replacement, RAM: Schritt 4, Bild 1 von 2 Sony Vaio VPCEB11FM RAM Replacement, RAM: Schritt 4, Bild 2 von 2
    • Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
    • Once the cover has been loosened, pry the cover with your finger for it to come off.
  5. Sony Vaio VPCEB11FM RAM Replacement: Schritt 5, Bild 1 von 3 Sony Vaio VPCEB11FM RAM Replacement: Schritt 5, Bild 2 von 3 Sony Vaio VPCEB11FM RAM Replacement: Schritt 5, Bild 3 von 3
    • Use your fingers to gently pull the white plastic strip outward on both sides.
    • Once you pull the strip, the strip of RAM will loosen up. Once loose the strip of RAM should lift out.
    • Once done with the top strip of RAM continue for all continuous strips.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Maxine Filcher
1.153 Reputation
8 Anleitungen geschrieben
UW Tacoma, Team 1-5, Rose Winter 2017 Mitglied von UW Tacoma, Team 1-5, Rose Winter 2017
UWT-ROSE-W17S1G5
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 1,667
