Zum Hauptinhalt wechseln
Sony Vaio VPCEG26FX RAM Replacement
Was du brauchst
  1. Sony Vaio VPCEG26FX  RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop so the bottom is facing up with the model number visible.
  2. Sony Vaio VPCEG26FX  RAM Replacement: Schritt 2, Bild 1 von 2 Sony Vaio VPCEG26FX  RAM Replacement: Schritt 2, Bild 2 von 2
    • Slide the lock switch down until you hear a click to unlock the battery.
  3. Sony Vaio VPCEG26FX  RAM Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VPCEG26FX  RAM Replacement: Schritt 3, Bild 2 von 2
    • Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place.
  4. Sony Vaio VPCEG26FX  RAM Replacement: Schritt 4, Bild 1 von 2 Sony Vaio VPCEG26FX  RAM Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery from the battery compartment.
  5. Sony Vaio VPCEG26FX  RAM Replacement, RAM: Schritt 5, Bild 1 von 1
    • After you remove the battery, there is a small rectangular panel underneath where the battery was housed.
  6. Sony Vaio VPCEG26FX  RAM Replacement: Schritt 6, Bild 1 von 1
    • Remove the single screw holding the panel in place using the JIS #0 screwdriver.
  7. Sony Vaio VPCEG26FX  RAM Replacement: Schritt 7, Bild 1 von 3 Sony Vaio VPCEG26FX  RAM Replacement: Schritt 7, Bild 2 von 3 Sony Vaio VPCEG26FX  RAM Replacement: Schritt 7, Bild 3 von 3
    • Remove the green circuit board by dislodging the circuit it is attached to.
    • Unhook it and remove it from the device.
Abschluss
Sara Alfaro
546 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S1-G4, Botvin Spring 2019 Mitglied von UMass Dartmouth, Team S1-G4, Botvin Spring 2019
UMASSD-BOTVIN-S19S1G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 760
