Zum Hauptinhalt wechseln
Sony Vaio VPCEL17FX Hard Drive Replacement
Was du brauchst
  1. Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 3 Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 3 Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    • First, locate the hard drive slot on the under side of the laptop.
    • Unscrew the screws using your Phillips #00 screwdriver.
    • Set the two screws aside so you can screw them in later on when you're finished.
    • This should reveal a small metallic place holder that your hard drive belongs.
  2. Sony Vaio VPCEL17FX Hard Drive Replacement: Schritt 2, Bild 1 von 2 Sony Vaio VPCEL17FX Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the 4 hard drive bracket screws.
    • Once the screw is undone you can pull the place holder back to find the slot where the actual hard drive belongs.
    • Remember to set aside the screw so you can correctly install the hard drive.
Abschluss
The installation/replacement is a very easy task that can be done by anyone.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 622
