Einleitung
The disk drive replacement is intended to show a simple way to remove and replace a disk drive.
Note: Do not pull disk drive out with force, as it can damage disk drive panel.
Was du brauchst
Remove the 9mm Phillips #1 screw holding the disk drive in place.
Remove the 9mm screw near the memory stick.
Using an iFixit opening tool, carefully pry the disk drive away from the device.
Eine weitere Person hat diese Anleitung absolviert.
