Einleitung
This guide will show you how to replace the fan in your Sony Vaio computer. You will need to have completed the keyboard replacement guide first.
Was du brauchst
Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
Carefully detach the ribbon from the base of the computer with your hands.
Remove the keyboard.
Using a metal spudger, pry open at the seams.
Open the gray top of the laptop from the base black portion.
Slide the spudger along the seam, and then carefully open the top.
The fan will still be attached by a small red and yellow wire, with your fingers detach this carefully.
Remove the fan.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
