Einleitung
This guide will show you how to replace the RAM in your Sony Vaio laptop.
  1. Start with the laptop face up on a flat surface.
    • Start with the laptop face up on a flat surface.
  2. Open the laptop with the keyboard facing you.
    • Open the laptop with the keyboard facing you.
    • Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
    • Be careful around the edges; work your way around the keyboard until all of it is detached.
    • There will be a ribbon cable attached to the bottom of the keyboard. Be sure not to rip the cable when lifting the keyboard from the laptop frame.
    • Carefully detach the ribbon from the base of the computer with your hands.
    • Remove the keyboard.
    • Use a Philips #0 screwdriver to remove the 7 top case screws.
    • Using a metal spudger, pry open at the seams.
    • Open the gray top of the laptop from the base black portion.
    • Slide the spudger along the seam, and then carefully open the top.
    • Open the top carefully without disconnecting the two parts.
    • Be mindful and careful of the ribbon cable attaching the two parts together.
    • Using your fingers, pry apart the two side metal pieces that hold the part in place as shown on the picture.
    • After that step, the RAM should pop up on its own as shown in the picture.
    • Carefully press the sides near the right edge of the part and remove it from it's base.
Abschluss
Giselle Dougan
Mitglied seit 31.01.2018
727 Reputation
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 119
