Einleitung
This guide will show you how to replace the RAM in your Sony Vaio laptop.
Was du brauchst
Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
Carefully detach the ribbon from the base of the computer with your hands.
Remove the keyboard.
Using a metal spudger, pry open at the seams.
Open the gray top of the laptop from the base black portion.
Slide the spudger along the seam, and then carefully open the top.
Using your fingers, pry apart the two side metal pieces that hold the part in place as shown on the picture.
Carefully press the sides near the right edge of the part and remove it from it's base.
Ein Kommentar
I have a 21212L and you have to remove the screws under the flap to remove the keyboard firstm you also do not have to remove the top assembly at all.
