Einleitung
In this guide, you will learn how to remove and replace the CD Drive from your laptop. if you have this exact laptop, follow the below steps. If you have another laptop, that is still okay, these steps will give you a basic understanding on how to remove the CD Drive and you can adapt them to your own computer.
Was du brauchst
Place your device upside down with the bottom panel facing upwards.
Orient the device so the battery is away from you as shown
Unlock the battery by sliding the lock switch to the right.
Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
Grab the center of the drive and pull away from the computer. It should slide right out.
