Zum Hauptinhalt wechseln
Sony Vaio VPCW21FX Hard Drive Replacement
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. Sony Vaio VPCW21FX Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure your device is powered off and unplugged to avoid electric shock.
    • Place your device upside down with the bottom panel facing upwards.
    • Orient the device so the battery is away from you as shown
  2. Sony Vaio VPCW21FX Hard Drive Replacement: Schritt 2, Bild 1 von 2 Sony Vaio VPCW21FX Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Unlock the battery by sliding the lock switch to the right.
    • Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
    • Be sure to lift up on the battery while you slide the latch to the left.
  3. Sony Vaio VPCW21FX Hard Drive Replacement: Schritt 3, Bild 1 von 2 Sony Vaio VPCW21FX Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Remove the battery from your laptop.
  4. Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 3 Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 3 Sony Vaio VPCW21FX Hard Drive Replacement, Hard Drive: Schritt 4, Bild 3 von 3
    • Remove the two 4.8mm screws that are holding the bottom right panel cover.
    • Remove the Panel cover by lifting it up.
  5. Sony Vaio VPCW21FX Hard Drive Replacement: Schritt 5, Bild 1 von 2 Sony Vaio VPCW21FX Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Remove the two 4.8mm screws that are holding the hard drive down.
  6. Sony Vaio VPCW21FX Hard Drive Replacement: Schritt 6, Bild 1 von 3 Sony Vaio VPCW21FX Hard Drive Replacement: Schritt 6, Bild 2 von 3 Sony Vaio VPCW21FX Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Grab the black tab that is attached to the hard drive.
    • Slide hard drive to the left to release it from the computer
    • Pull drive up from there and it will come out.
Abschluss
Nicholas Corcoran
401 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S2-G5, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S2-G5, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G5
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 532
