Zum Hauptinhalt wechseln
Sony Vaio VPCW21FX Keyboard Replacement
Was du brauchst
  1. Sony Vaio VPCW21FX Keyboard Replacement, Battery: Schritt 1, Bild 1 von 3 Sony Vaio VPCW21FX Keyboard Replacement, Battery: Schritt 1, Bild 2 von 3 Sony Vaio VPCW21FX Keyboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX Keyboard Replacement: Schritt 2, Bild 1 von 3 Sony Vaio VPCW21FX Keyboard Replacement: Schritt 2, Bild 2 von 3 Sony Vaio VPCW21FX Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 3 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 3 Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Open the Lid of the laptop
    • Then using they pry tool to carefully remove the plastic cover around the keyboard
    • It helps to pry from one of the larger keys as they have more room to fit the tool in
  4. Sony Vaio VPCW21FX Keyboard Replacement: Schritt 4, Bild 1 von 3 Sony Vaio VPCW21FX Keyboard Replacement: Schritt 4, Bild 2 von 3 Sony Vaio VPCW21FX Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Close the lid and flip the laptop over
    • Loosen but do not remove the screw on center panel and remove Panel.
  5. Sony Vaio VPCW21FX Keyboard Replacement: Schritt 5, Bild 1 von 2 Sony Vaio VPCW21FX Keyboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the three 5mm screws that are holding in the keyboard.
  6. Sony Vaio VPCW21FX Keyboard Replacement: Schritt 6, Bild 1 von 3 Sony Vaio VPCW21FX Keyboard Replacement: Schritt 6, Bild 2 von 3 Sony Vaio VPCW21FX Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Flip laptop over again and open the lid
    • Lift up the keyboard from the top and lean it toward you to expose the connector on the back
    • Grab the wire from the keyboard close to the connector and pull carefully to the left to disconnect it from the laptop.
Abschluss
Nicholas Corcoran
401 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S2-G5, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S2-G5, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G5
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 25
Insgesamt: 2,220
