Zum Hauptinhalt wechseln
Sony Vaio VPCW21FX RAM Replacement
Was du brauchst
  1. Sony Vaio VPCW21FX RAM Replacement, Battery: Schritt 1, Bild 1 von 3 Sony Vaio VPCW21FX RAM Replacement, Battery: Schritt 1, Bild 2 von 3 Sony Vaio VPCW21FX RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX RAM Replacement: Schritt 2, Bild 1 von 3 Sony Vaio VPCW21FX RAM Replacement: Schritt 2, Bild 2 von 3 Sony Vaio VPCW21FX RAM Replacement: Schritt 2, Bild 3 von 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX RAM Replacement, RAM: Schritt 3, Bild 1 von 3 Sony Vaio VPCW21FX RAM Replacement, RAM: Schritt 3, Bild 2 von 3 Sony Vaio VPCW21FX RAM Replacement, RAM: Schritt 3, Bild 3 von 3
    • Loosen but do not remove the screw over RAM cover panel.
    • With the screw loosened but not removed, lift up and remove the panel.
  4. Sony Vaio VPCW21FX RAM Replacement: Schritt 4, Bild 1 von 3 Sony Vaio VPCW21FX RAM Replacement: Schritt 4, Bild 2 von 3 Sony Vaio VPCW21FX RAM Replacement: Schritt 4, Bild 3 von 3
    • Locate the mounting bracket holding the RAM Chips in the computer.
    • Pull silver tabs away from the chip.
    • The chip will pop up, this is normal.
    • Don't touch gold pins on RAM chip.
  5. Sony Vaio VPCW21FX RAM Replacement: Schritt 5, Bild 1 von 2 Sony Vaio VPCW21FX RAM Replacement: Schritt 5, Bild 2 von 2
    • Slide RAM chip out by holding the sides of the chip and pull away from the computer.
    • Repeat previous steps for second RAM chip.
Abschluss
Nicholas Corcoran
401 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S2-G5, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S2-G5, Isaacson Spring 2017
UMASSD-ISAACSON-S17S2G5
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 22
Insgesamt: 3,345
