Zum Hauptinhalt wechseln
Sony Walkman NWZ-E438 Battery Replacement
Was du brauchst
  1. Sony Walkman NWZ-E438 Battery Replacement, Disassembling Sony Walkman NWZ-E438: Schritt 1, Bild 1 von 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Peel back the black tape from the device to the battery from the side of the device.
  4. Sony Walkman NWZ-E438 Battery Replacement: Schritt 4, Bild 1 von 1
    • Using a small, plastic prying tool slowly lift the battery around all edges.
    • Careful of wires connecting the battery to the device.
  5. Sony Walkman NWZ-E438 Battery Replacement: Schritt 5, Bild 1 von 1
    • Remove the yellow film covering the circuit board with pointed precision tweezers.
  6. Sony Walkman NWZ-E438 Battery Replacement: Schritt 6, Bild 1 von 2 Sony Walkman NWZ-E438 Battery Replacement: Schritt 6, Bild 2 von 2
    • Using tweezers, unplug the gold band connecting the device and circuit board.
  7. Sony Walkman NWZ-E438 Battery Replacement: Schritt 7, Bild 1 von 2 Sony Walkman NWZ-E438 Battery Replacement: Schritt 7, Bild 2 von 2
    • Using pointed precision tweezers, unplug the wires connecting the battery and chip from the chip.
  8. Sony Walkman NWZ-E438 Battery Replacement: Schritt 8, Bild 1 von 1
    • Remove battery.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Do you have a link to purchase a replacement battery? Thanks!
jacob goff - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 41
Insgesamt: 6,454
