Zum Hauptinhalt wechseln
Sony Walkman NWZ-E438 Headphone Jack Replacement
Was du brauchst
  1. Sony Walkman NWZ-E438 Headphone Jack Replacement, Disassembling Sony Walkman NWZ-E438: Schritt 1, Bild 1 von 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Headphone Jack Replacement, Headphone Jack: Schritt 3, Bild 1 von 1
    • Unscrew the 1 screws around the headphone jack using Phillips PH000 screwdriver.
  4. Sony Walkman NWZ-E438 Headphone Jack Replacement: Schritt 4, Bild 1 von 2 Sony Walkman NWZ-E438 Headphone Jack Replacement: Schritt 4, Bild 2 von 2
    • Using the fine pointed tweezers, unplug the cords connecting the headphone jack to the chip.
  5. Sony Walkman NWZ-E438 Headphone Jack Replacement: Schritt 5, Bild 1 von 3 Sony Walkman NWZ-E438 Headphone Jack Replacement: Schritt 5, Bild 2 von 3 Sony Walkman NWZ-E438 Headphone Jack Replacement: Schritt 5, Bild 3 von 3
    • Remove the headphone jack.
Abschluss
2 Kommentare
hi there, i have mine apart but where do i get a spare one to refit, please help
lee manock - Antwort
Can you make a tutorial on how to replace the headphone jack on the sony nwz-s774?
petermedz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 811
