Zum Hauptinhalt wechseln
Sony Walkman NWZ-E438 Screen Replacement
Was du brauchst
  1. Sony Walkman NWZ-E438 Screen  Replacement, Disassembling Sony Walkman NWZ-E438: Schritt 1, Bild 1 von 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Screen  Replacement: Schritt 2, Bild 1 von 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Screen  Replacement, Screen: Schritt 3, Bild 1 von 1
    • Pull up the 2 copper strips connecting the outside of the device to the inside of the device.
  4. Sony Walkman NWZ-E438 Screen  Replacement: Schritt 4, Bild 1 von 1
    • Using the small, plastic prying tool wedge it between the bottom of the frame and the outer frame.
    • Slowly circle the device, popping the outside of the frame off.
  5. Sony Walkman NWZ-E438 Screen  Replacement: Schritt 5, Bild 1 von 1
    • To remove the screen, use the fine point tweezers and lift up on the metal piece at the bottom of the frame.
  6. Sony Walkman NWZ-E438 Screen  Replacement: Schritt 6, Bild 1 von 1
    • To remove screen from metal backing, use fine point tweezers to go in between the screen and metal backing and slowly pull them apart.
  7. Sony Walkman NWZ-E438 Screen  Replacement: Schritt 7, Bild 1 von 1
    • The screen will be removed.
Abschluss
Ein Kommentar
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 676
