Zum Hauptinhalt wechseln
Sony Walkman NWZ-E438 USB Port Replacement
Was du brauchst
  1. Sony Walkman NWZ-E438 USB Port Replacement, Disassembling Sony Walkman NWZ-E438: Schritt 1, Bild 1 von 1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 USB Port Replacement: Schritt 2, Bild 1 von 1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: Schritt 3, Bild 1 von 3 Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: Schritt 3, Bild 2 von 3 Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: Schritt 3, Bild 3 von 3
    • First, you must remove the black tape on the circuit board.
    • Next, pull up on the red and gold band until it detaches from the chip.
  4. Sony Walkman NWZ-E438 USB Port Replacement: Schritt 4, Bild 1 von 2 Sony Walkman NWZ-E438 USB Port Replacement: Schritt 4, Bild 2 von 2
    • Using a small plastic prying tool, slip the end under the device circuit board and slowly lift it.
    • Once the circuit board is lifted, carefully remove the chip with tweezers.
    • The circuit board will still be connected to the device by a wire.
  5. Sony Walkman NWZ-E438 USB Port Replacement: Schritt 5, Bild 1 von 1
    • Using a soldering iron, carefully heat the metal connecting the wires from the device to the circuit board.
    • You will need the soldering iron to reattach those wires once you've replaced the circuit board.
  6. Sony Walkman NWZ-E438 USB Port Replacement: Schritt 6, Bild 1 von 1
    • Carefully remove the circuit board from the device.
  7. Sony Walkman NWZ-E438 USB Port Replacement, USB Port: Schritt 7, Bild 1 von 1
    • Using fine point tweezers, push them between the chip and USB port.
  8. Sony Walkman NWZ-E438 USB Port Replacement: Schritt 8, Bild 1 von 1
    • Slowly pry the USB port off of the chip.
    • You will need to solder the new USB onto the circuit board.
  9. Sony Walkman NWZ-E438 USB Port Replacement: Schritt 9, Bild 1 von 1
    • Remove USB port.
Abschluss
Ein Kommentar
Wher buy new port????pavel87cz@gmail.com
Pavel Drobny - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 587
