Zum Hauptinhalt wechseln
  1. Remove the two black 6.4mm Phillips screws from the back of the device. Remove the two black 6.4mm Phillips screws from the back of the device. Remove the two black 6.4mm Phillips screws from the back of the device.
    • Remove the two black 6.4mm Phillips screws from the back of the device.
  2. Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel. Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel. Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
    • Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
  3. Laptop-Akkus
    Wenig Aufwand, große Wirkung.
    Jetzt kaufen
    Laptop-Akkus
    Jetzt kaufen
  4. Remove the two 2.8 mm phillips screws located on either side of the device near the top. Remove the two 2.8 mm phillips screws located on either side of the device near the top.
    • Remove the two 2.8 mm phillips screws located on either side of the device near the top.
  5. Carefully pull the top piece away from the device. Carefully pull the top piece away from the device.
    • Carefully pull the top piece away from the device.
  6. Use the flat end of the spudger to flip up the retaining flap for the bluetooth module. Be sure to lift up on the retaining flap, and not the socket itself. Be sure to lift up on the retaining flap, and not the socket itself.
    • Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
    • Be sure to lift up on the retaining flap, and not the socket itself.
  7. Remove the two 1.8mm silver Phillips screws on the Bluetooth module. Lift up on and remove the Bluetooth module. The ribbon cable must first be removed in order to access the highlighted screw.
    • Remove the two 1.8mm silver Phillips screws on the Bluetooth module.
    • Lift up on and remove the Bluetooth module.
    • The ribbon cable must first be removed in order to access the highlighted screw.
Abschluss
John Ferguson
597 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 4-2, Brown Winter 2015 Mitglied von USF Tampa, Team 4-2, Brown Winter 2015
USFT-BROWN-W15S4G2
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 378
