Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
If your Walkman is working but you cannot play cassettes, you may need to replace the band that connects the film revolvers. This guide shows you how to do so.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove any batteries or cassettes from the Walkman.
    • Remove any batteries or cassettes from the Walkman.
  2. Using a spudger, separate the back cover from the front. Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell. Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
  3. Replace the band, ensuring that it wraps around both large plastic revolvers and the small metal one.
    • Replace the band, ensuring that it wraps around both large plastic revolvers and the small metal one.
  4. This picture shows how the belt was set when I opened a Walkman WM-FX10.
    • This picture shows how the belt was set when I opened a Walkman WM-FX10.
    • I think you can rely on the same arrangement in other Walkman's
Abschluss
7 weitere Nutzer haben diese Anleitung absolviert.
Wilson Riforgiat
801 Reputation
4 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 Mitglied von USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014
USFSM-STEWART-F14S1G4
4 Mitglieder
14 Anleitungen geschrieben
"How to replace the band":
Step 1: Open it.
Step 2: Replace the band.
Really? That's it?! Not very useful.
No Thanks - Antwort
I need to know the belt track. I'm thinking there is a particular path the belt must follow. Do you know it? Your photo shows no belt (band).
jcalla704 - Antwort
Helped. Wanted an idea of how to open, before breaking it!
Troyf - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 5
Letzten 7 Tage: 18
Letzten 30 Tage: 123
Insgesamt: 10,877
