Einleitung
This repair guide will help you install a new USB cable for your car unit. It will ultimately enhance your experience while connecting the device to your car. This process requires you having a tool kit, specifically, the PH#0 screwdriver and a spudger. With that said, you should be good to go!
Was du brauchst
Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
Remove the ten 3.5mm Phillips #0 screws from the back plate.
Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
Pull the USB cable off of the back plate.
Eine weitere Person hat diese Anleitung absolviert.
