Zum Hauptinhalt wechseln
Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update
Einführungsvideo
  1. Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update, Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 1, Bild 1 von 3 Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update, Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 1, Bild 2 von 3 Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update, Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 1, Bild 3 von 3
  2. Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 2, Bild 1 von 2 Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 2, Bild 2 von 2
    • Install PC Companion.
  3. Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 3, Bild 1 von 3 Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 3, Bild 2 von 3 Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 3, Bild 3 von 3
    • From here you can update firmware to your devise but it must be powered on not screen locked.
    • Start "Support Zone".
    • Select "Phone / Tablet Software Update".
  4. Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 4, Bild 1 von 3 Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 4, Bild 2 von 3 Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 4, Bild 3 von 3
    • Your Laptop must be connected to the power adapter.
    • Select "repair my phone / tablet".
    • The last warning for your personal data.
  5. Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 5, Bild 1 von 2 Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 5, Bild 2 von 2
    • PC Companion will download some files to prepare your PC for update.
    • Your battery of the tablet must be charged at last 80%.
  6. Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 6, Bild 1 von 1
    • Select your device.
  7. Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 7, Bild 1 von 3 Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 7, Bild 2 von 3 Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 7, Bild 3 von 3
    • Switch off the tablet. If you can't do this, press and hold for more time the power on button.
    • Press and hold the volume down button until you connect the micro USB cable.
    • When the PC recognized the device, PC companion will download the latest firmware version and will upload it to your tablet.
  8. Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 8, Bild 1 von 3 Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 8, Bild 2 von 3 Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 8, Bild 3 von 3
    • If your PC can't recognize your tablet, you must install drivers for it. Search in the internet for "S1Boot Fastboot" drivers, or download the drivers from the link below.
    • F1Boot Fastboot drivers
  9. Sony XPERIA Tablet Z - Password Removal, Factory / Hard Reset, Firmware Update: Schritt 9, Bild 1 von 1
    • When PC Companion finished, disconnect the tablet and switch it on.
    • The device is at factory state, with the latest firmware version and erased security protection.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.308 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.532 Anleitungen geschrieben
2 Kommentare
How to remove a password, you need a password to do soo ....
Carol Sanchez - Antwort
There is a known problem with Sony tabs. If you use a locking code in which two zeros follow each other numerically . You lock yourself out, no version works ! Get the one with two zeros “00”, nor the one with “0” functioned.
If u not create a Sony-account and 2015 u do not need an alternative email address for your Google account. You can chuck away your Tab. Mine has been on the shelf since 5 years
Awto - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 50
Insgesamt: 61,238
