Zum Hauptinhalt wechseln
Sony XPERIA Tablet Z Screen Replacement
Was du brauchst
  1. Sony XPERIA Tablet Z Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Sony XPERIA Tablet Z Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Sony XPERIA Tablet Z Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Remove the back cover by lifting up one corner using the plastic opening tool, and then removing the adhesive around the cover.
  2. Sony XPERIA Tablet Z Screen Replacement: Schritt 2, Bild 1 von 3 Sony XPERIA Tablet Z Screen Replacement: Schritt 2, Bild 2 von 3 Sony XPERIA Tablet Z Screen Replacement: Schritt 2, Bild 3 von 3
    • Gently separate the gold ribbon cable from the back side by lifting up with plastic opening tool and separating from the adhesive.
    • Separate the black ribbon cable from the back of screen by lifting up with a plastic opening tool.
  3. Sony XPERIA Tablet Z Screen Replacement: Schritt 3, Bild 1 von 1
    • Use a hairdryer, heat gun, or something suitable to heat the edge of the screen to soften the adhesive holding the screen.
    • Only heat enough to loosen the adhesive but not damage the tablet.
  4. Sony XPERIA Tablet Z Screen Replacement: Schritt 4, Bild 1 von 1
    • Gently pry the edge of the screen working around while heating.
  5. Sony XPERIA Tablet Z Screen Replacement: Schritt 5, Bild 1 von 1
    • Clean adhesive from perimeter of frame to prepare for new screen.
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team S5-G1, Harley Summer 2017 Mitglied von IUPUI, Team S5-G1, Harley Summer 2017
IUPUI-HARLEY-SU17S5G1
4 Mitglieder
3 Anleitungen geschrieben
5 Kommentare
اريدشراءاريدشراءشاشه جديده
kore ares - Antwort
Do you need adhesive to attach new screen, & if so, what do you use?
Martha Morrison - Antwort
i would also like to know what adhesive you use to reatach the screen. thanks
Blaze - Antwort
Wooo its self explanatory.Good work
Duncan Mwaniki - Antwort
Where do I get the Screen if I'm in South Africa
Thembekile Nizel - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 81
Insgesamt: 7,137
