Einleitung
Use this guide to replace the speakers in your Sony XPERIA Tablet Z.
In this device there are two speakers each located in a bottom corners of the tablet.
This guide will take you through the process of removing the back cover, removing the retaining plate, and removing the speaker.
Was du brauchst
Slide the plastic opening tool along the edge of the device removing the adhesive.
Remove the back cover.
Clean the adhesive off the inside perimeter of the device.
Remove the 2.96mm long Phillips head #0 retaining screw from each speaker.
Lift off the silver speaker retaining plate.
3 weitere Personen haben diese Anleitung absolviert.
