Zum Hauptinhalt wechseln
Sony Xperia 10 VI Screen Replacement
Was du brauchst
  1. Sony Xperia 10 VI Screen Replacement, Screen Replacement: Schritt 1, Bild 1 von 1
    • Replacing the screen on this mobile is quite involved. You have to detach the screen and also to open the backside to get to the connector.
  2. Sony Xperia 10 VI Screen Replacement, Remove Back Cover: Schritt 2, Bild 1 von 1
    • To remove the back cover, you have to do the usual: heating with a heat gun and then pry it open with opening picks.
  3. Sony Xperia 10 VI Screen Replacement, Detach Screen: Schritt 3, Bild 1 von 1
    • As a next step, heat evenly along the side of the screen with the heat gun. Pry open carefully from the bottom where the microphone is located, as all the other sides are too tight to get into. Be careful with the screen connector, this is attached to the screen on the bottom right when looked at from above. It cannot be disconnected at this step.
  4. Sony Xperia 10 VI Screen Replacement, Remove Screen Connector: Schritt 4, Bild 1 von 1
    • Remove the six screws which hold the charge cover using a PH000 screwdriver.
  5. Sony Xperia 10 VI Screen Replacement, Remove the Charger Board: Schritt 5, Bild 1 von 1
    • As the charger board overlaps the screen connector, it needs to be removed. For this, you'll need to disconnect the cable press connector and the two flex cable connectors.
  6. Sony Xperia 10 VI Screen Replacement, Detach Screen: Schritt 6, Bild 1 von 1
    • With the charger board (grey) removed, you are able to detach the screen from the press cable connector.
  7. Sony Xperia 10 VI Screen Replacement, New Screen and Re-Assemblement: Schritt 7, Bild 1 von 1
    • Now attach the new screen, reassemble (use suitable glue for screen and backcover) and enjoy.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Romax
334 Reputation
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 22
Letzte 30 Tage: 89
Insgesamt: 842
