Einleitung
E2104, E2105, E2115, E2124
How to disassemble, take apart the device and change / replace broken touch screen glass digitizer, LCD
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Einführungsvideo
Remove the back cover and any installed SIM and memory cards.
There are 8x black screws Torx T4. Remove them.
Remove the small black rubber at the lower left corner.
Under it is the battery flex cable, disconnect it.
Use a plastic tool to separate the middle frame.
The battery is glued to the middle frame with an adhesive tape.
Loudspeaker
Disconnect the touch screen flex cable.
Under it is the LCD flex cable. Disconnect it also.
Cover the glass with a scotch tape.
Warm the glass for about minute.
With a cutter lift a little the glase to make a room for the plastic tool.
Carefully put the plastic tool between the glass and the LCD.
Remove the display frame.
12 weitere Nutzer haben diese Anleitung absolviert.
4 Kommentare
Grazie! È stato davvero utilissimo. :)
Doesn't the original glass and digitalizer come out with its biadesive?
