Einleitung
This guide will take you step by step through the process of replacing your Sony Xperia L2 charging port. This guide will with an inoperable or faulty charging port to extend battery life.
Was du brauchst
Use the plastic opening tool to pry the back case of the phone off.
Disconnect the fingerprint sensor.
Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
Disconnect the battery cable from the motherboard.
Pry up the battery and remove it from the device.
Use a plastic opening tool to lift the charging port circuit board.
Unhook the antenna from circuit board using a plastic opening tool and remove the charging port circuit board from the device.
