Einleitung
This guide will take you step by step through the process of replacing your Sony Xperia L2 screen. This guide will help those who have a broken or unresponsive screen to extend the life of your phone.
Was du brauchst
Use the plastic opening tool to pry the back case of the phone off.
Disconnect the fingerprint sensor.
Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
Disconnect the battery cable from the motherboard.
Pry up the battery and remove it from the device.
Microwave the iOpener for 30 seconds.
Place the iOpener on the phone screen for 90 seconds to loosen the adhesive.
Use the suction tool and a pick to remove the screen from the phone.
2 weitere Personen haben diese Anleitung absolviert.
