Zum Hauptinhalt wechseln
Sony Xperia L2 LTE Screen Replacement
Was du brauchst
  1. Sony Xperia L2 LTE Screen Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Xperia L2 LTE Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Sony Xperia L2 LTE Screen Replacement: Schritt 2, Bild 1 von 3 Sony Xperia L2 LTE Screen Replacement: Schritt 2, Bild 2 von 3 Sony Xperia L2 LTE Screen Replacement: Schritt 2, Bild 3 von 3
    • Use the plastic opening tool to pry the back case of the phone off.
    • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
  3. Sony Xperia L2 LTE Screen Replacement: Schritt 3, Bild 1 von 1
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
  4. Sony Xperia L2 LTE Screen Replacement: Schritt 4, Bild 1 von 2 Sony Xperia L2 LTE Screen Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  5. Sony Xperia L2 LTE Screen Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Unclip circuit connectors from phone to motherboard.
  6. Sony Xperia L2 LTE Screen Replacement: Schritt 6, Bild 1 von 3 Sony Xperia L2 LTE Screen Replacement: Schritt 6, Bild 2 von 3 Sony Xperia L2 LTE Screen Replacement: Schritt 6, Bild 3 von 3
    • Use blue plastic opening tool to pry off the motherboard.
  7. Sony Xperia L2 LTE Screen Replacement, Screen: Schritt 7, Bild 1 von 2 Sony Xperia L2 LTE Screen Replacement, Screen: Schritt 7, Bild 2 von 2
    • Microwave the iOpener for 30 seconds.
    • Place the iOpener on the phone screen for 90 seconds to loosen the adhesive.
    • Use the suction tool and a pick to remove the screen from the phone.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  8. Sony Xperia L2 LTE Screen Replacement: Schritt 8, Bild 1 von 1
    • Unhook the screen sensor from the phone to detach the screen from the device.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Very helpful thanks
Stix - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 20
Letzte 30 Tage: 52
Insgesamt: 1,577
