Zum Hauptinhalt wechseln
Sony Xperia M2 Earpiece Replacement
Was du brauchst
Einführungsvideo
  1. Sony Xperia M2 Earpiece Replacement, Rear Cover: Schritt 1, Bild 1 von 3 Sony Xperia M2 Earpiece Replacement, Rear Cover: Schritt 1, Bild 2 von 3 Sony Xperia M2 Earpiece Replacement, Rear Cover: Schritt 1, Bild 3 von 3
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Cover is plastic.
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one if your spare part has come without double sided adhesive tape.
  2. Sony Xperia M2 Earpiece Replacement, Battery: Schritt 2, Bild 1 von 3 Sony Xperia M2 Earpiece Replacement, Battery: Schritt 2, Bild 2 von 3 Sony Xperia M2 Earpiece Replacement, Battery: Schritt 2, Bild 3 von 3
    • Disconnect the Battery Cable.
    • The battery is stuck to the phone fame. Use the white tape to remove it.
    • Li-Polymer Battery, 2230 mAh
    • Part number: LIS1551ERPC
    • Please SUBSCRIBE to my channel ツ
  3. Sony Xperia M2 Earpiece Replacement, Logic Board: Schritt 3, Bild 1 von 2 Sony Xperia M2 Earpiece Replacement, Logic Board: Schritt 3, Bild 2 von 2
    • Remove the SIM and the memory cards.
    • Remove x4 T5 Torx Corner screws & x2 T5 Torx Screws on the Board
  4. Sony Xperia M2 Earpiece Replacement: Schritt 4, Bild 1 von 1
    • Disconnect one by one:
    • Touchscreen flex cable
    • Proximity sensor flex cable
    • Power on, Volume buttons cable
    • SIM & Micro SD flex cable
    • Coaxial antenna cable
  5. Sony Xperia M2 Earpiece Replacement: Schritt 5, Bild 1 von 2 Sony Xperia M2 Earpiece Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the LCD Display flex cable. The connector is on the other side of the board, under the Power/Volume buttons flex cable connector.
    • Put one plastic spudger between the Logic board and the Main frame.
  6. Sony Xperia M2 Earpiece Replacement: Schritt 6, Bild 1 von 3 Sony Xperia M2 Earpiece Replacement: Schritt 6, Bild 2 von 3 Sony Xperia M2 Earpiece Replacement: Schritt 6, Bild 3 von 3
    • Step one: move aside less the left side of the board - down.
    • Step two: the left side of the Logic board must go out of the main frame.
    • For this manipulation use only plastic tools.
  7. Sony Xperia M2 Earpiece Replacement, Earpiece: Schritt 7, Bild 1 von 3 Sony Xperia M2 Earpiece Replacement, Earpiece: Schritt 7, Bild 2 von 3 Sony Xperia M2 Earpiece Replacement, Earpiece: Schritt 7, Bild 3 von 3
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.368 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.468 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 4,246
