Einleitung
This is a step by step demonstration to disassembling the Sony Xperia S
Was du brauchst
Then, detach the first bus (indicated with the red circle) to fully detach the case.
After removing the buses, we can remove the camera and the motherboard. Proceed to remove the motherboard.
To reassemble your device, follow the instructions in reverse order
3 weitere Personen haben diese Anleitung absolviert.
100%
Henry Ko hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
4 Kommentare zur Anleitung
hi..my xperia s totally crashed..it is not working at all..is there any way to get the data from the sd card..!!??please help..if i disassembled it ..can i run the sd card on another device or something like that or any thing ..please help..:(
estoy en la misma situación, pudiste encontrar la sd?
،سلام، ال،سی،دی این گوشی چنده ، و از کجا بگیرم.؟
