Zum Hauptinhalt wechseln
Sony Xperia Sola Battery Replacement
Was du brauchst
  1. Sony Xperia Sola Battery Replacement, Motherboard: Schritt 1, Bild 1 von 2 Sony Xperia Sola Battery Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Place phone down with screen side down and camera side facing up as shown.
    • Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
  2. Sony Xperia Sola Battery Replacement: Schritt 2, Bild 1 von 3 Sony Xperia Sola Battery Replacement: Schritt 2, Bild 2 von 3 Sony Xperia Sola Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the five (5) screws on the phone, using a screwdriver. The screws are at the top and the bottom of the phone as shown.
  3. Sony Xperia Sola Battery Replacement: Schritt 3, Bild 1 von 2 Sony Xperia Sola Battery Replacement: Schritt 3, Bild 2 von 2
    • Pry off the bottom white cover by using the opening tool as a lever.
  4. Sony Xperia Sola Battery Replacement: Schritt 4, Bild 1 von 2 Sony Xperia Sola Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the two additional screws using the Torx screwdriver.
  5. Sony Xperia Sola Battery Replacement: Schritt 5, Bild 1 von 2 Sony Xperia Sola Battery Replacement: Schritt 5, Bild 2 von 2
    • Locate the black cover on the bottom left of phone. Use an opening tool to pry up and remove the black cover.
  6. Sony Xperia Sola Battery Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the circuit by lifting the connector straight up as shown using the tweezers.
  7. Sony Xperia Sola Battery Replacement: Schritt 7, Bild 1 von 3 Sony Xperia Sola Battery Replacement: Schritt 7, Bild 2 von 3 Sony Xperia Sola Battery Replacement: Schritt 7, Bild 3 von 3
    • Turn the phone onto its side. Insert a plastic opening tool into seam, and gently remove the cover. You can also slide the spudger in from the top.
    • Once the cover is loose, lift it off the phone. The side buttons may feel a bit sticky, but this is normal.
  8. Sony Xperia Sola Battery Replacement: Schritt 8, Bild 1 von 1
    • Locate the additional circuit at the bottom left. Using the tweezers, remove it gently by pulling up.
  9. Sony Xperia Sola Battery Replacement: Schritt 9, Bild 1 von 2 Sony Xperia Sola Battery Replacement: Schritt 9, Bild 2 von 2
    • Use the tweezers to lift up on the circuit located at the top left.
  10. Sony Xperia Sola Battery Replacement: Schritt 10, Bild 1 von 1
    • Use the spudger and slide it under the top left of the board then lift the board straight up. The board should come up very easily.
  11. Sony Xperia Sola Battery Replacement, Remove and replace the battery.: Schritt 11, Bild 1 von 3 Sony Xperia Sola Battery Replacement, Remove and replace the battery.: Schritt 11, Bild 2 von 3 Sony Xperia Sola Battery Replacement, Remove and replace the battery.: Schritt 11, Bild 3 von 3
    • To remove the battery, slide the end of a plastic opening tool under the battery and lift it.
    • It is possible that the battery may be glued to the phone. If this is the case, use isopropyl alcohol or adhesive remover underneath the battery to soften the adhesive, then use a suction cup to lift the battery out.
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler. For optimal performance, calibrate your newly installed battery after completing this guide.
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 1-1, Brown Fall 2014 Mitglied von USF Tampa, Team 1-1, Brown Fall 2014
USFT-BROWN-F14S1G1
4 Mitglieder
5 Anleitungen geschrieben
3 Kommentare zur Anleitung
Thanks, battery successfully changed :-)
martinslunecko - Antwort Teilen
Thanx will do that when i get areplacement battery!
ndiwenijb - Antwort Teilen
hello where i can find a new battery ?
minigamer - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 28
Insgesamt: 3,584
