Zum Hauptinhalt wechseln
Sony Xperia Sola Camera Module Replacement
Was du brauchst
  1. Sony Xperia Sola Camera Module Replacement, Motherboard: Schritt 1, Bild 1 von 2 Sony Xperia Sola Camera Module Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Place phone down with screen side down and camera side facing up as shown.
    • Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
  2. Sony Xperia Sola Camera Module Replacement: Schritt 2, Bild 1 von 3 Sony Xperia Sola Camera Module Replacement: Schritt 2, Bild 2 von 3 Sony Xperia Sola Camera Module Replacement: Schritt 2, Bild 3 von 3
    • Remove the five (5) screws on the phone, using a screwdriver. The screws are at the top and the bottom of the phone as shown.
  3. Sony Xperia Sola Camera Module Replacement: Schritt 3, Bild 1 von 2 Sony Xperia Sola Camera Module Replacement: Schritt 3, Bild 2 von 2
    • Pry off the bottom white cover by using the opening tool as a lever.
  4. Sony Xperia Sola Camera Module Replacement: Schritt 4, Bild 1 von 2 Sony Xperia Sola Camera Module Replacement: Schritt 4, Bild 2 von 2
    • Remove the two additional screws using the Torx screwdriver.
  5. Sony Xperia Sola Camera Module Replacement: Schritt 5, Bild 1 von 2 Sony Xperia Sola Camera Module Replacement: Schritt 5, Bild 2 von 2
    • Locate the black cover on the bottom left of phone. Use an opening tool to pry up and remove the black cover.
  6. Sony Xperia Sola Camera Module Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the circuit by lifting the connector straight up as shown using the tweezers.
  7. Sony Xperia Sola Camera Module Replacement: Schritt 7, Bild 1 von 3 Sony Xperia Sola Camera Module Replacement: Schritt 7, Bild 2 von 3 Sony Xperia Sola Camera Module Replacement: Schritt 7, Bild 3 von 3
    • Turn the phone onto its side. Insert a plastic opening tool into seam, and gently remove the cover. You can also slide the spudger in from the top.
    • Once the cover is loose, lift it off the phone. The side buttons may feel a bit sticky, but this is normal.
  8. Sony Xperia Sola Camera Module Replacement: Schritt 8, Bild 1 von 1
    • Locate the additional circuit at the bottom left. Using the tweezers, remove it gently by pulling up.
  9. Sony Xperia Sola Camera Module Replacement: Schritt 9, Bild 1 von 2 Sony Xperia Sola Camera Module Replacement: Schritt 9, Bild 2 von 2
    • Use the tweezers to lift up on the circuit located at the top left.
  10. Sony Xperia Sola Camera Module Replacement: Schritt 10, Bild 1 von 1
    • Use the spudger and slide it under the top left of the board then lift the board straight up. The board should come up very easily.
  11. Sony Xperia Sola Camera Module Replacement, Place the board as shown.: Schritt 11, Bild 1 von 1
    • This will ensure easy removal of the camera module.
  12. Sony Xperia Sola Camera Module Replacement, Remove the camera's power.: Schritt 12, Bild 1 von 3 Sony Xperia Sola Camera Module Replacement, Remove the camera's power.: Schritt 12, Bild 2 von 3 Sony Xperia Sola Camera Module Replacement, Remove the camera's power.: Schritt 12, Bild 3 von 3
    • Using the tweezers remove the camera from the power source.
  13. Sony Xperia Sola Camera Module Replacement, Remove the camera module.: Schritt 13, Bild 1 von 1
    • Pick up board and remove camera module. The module should seem to just pop out.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 1-1, Brown Fall 2014 Mitglied von USF Tampa, Team 1-1, Brown Fall 2014
USFT-BROWN-F14S1G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 53
Insgesamt: 671
