Was du brauchst
Place phone down with screen side down and camera side facing up as shown.
Push on cover away from you. You should hear a snap or pop. This will let you view the battery and sim/sd card slots. Then lift the cover off.
Remove the five (5) screws on the phone, using a screwdriver. The screws are at the top and the bottom of the phone as shown.
Locate the black cover on the bottom left of phone. Use an opening tool to pry up and remove the black cover.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Disconnect the circuit by lifting the connector straight up as shown using the tweezers.
Turn the phone onto its side. Insert a plastic opening tool into seam, and gently remove the cover. You can also slide the spudger in from the top.
Once the cover is loose, lift it off the phone. The side buttons may feel a bit sticky, but this is normal.
Locate the additional circuit at the bottom left. Using the tweezers, remove it gently by pulling up.
Use the spudger and slide it under the top left of the board then lift the board straight up. The board should come up very easily.
5 weitere Personen haben diese Anleitung absolviert.
