Zum Hauptinhalt wechseln
Sony Xperia Sola Speaker Replacement
Was du brauchst
  1. Sony Xperia Sola Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Lay the phone as shown and put the camera facing up.
  2. Sony Xperia Sola Speaker Replacement: Schritt 2, Bild 1 von 2 Sony Xperia Sola Speaker Replacement: Schritt 2, Bild 2 von 2
    • Push the back cover as shown, then lift the cover off.
  3. Sony Xperia Sola Speaker Replacement: Schritt 3, Bild 1 von 3 Sony Xperia Sola Speaker Replacement: Schritt 3, Bild 2 von 3 Sony Xperia Sola Speaker Replacement: Schritt 3, Bild 3 von 3
    • Remove the five screws as shown on the phone by using 26 Bit Kit.
    • Use a T6 screwdriver bit to remove top two screws.
    • Use a J000 screwdriver bit to remove the bottom two screws.
    • Use a T3 screwdriver bit to remove the middle screw (close to camera).
  4. Sony Xperia Sola Speaker Replacement: Schritt 4, Bild 1 von 2 Sony Xperia Sola Speaker Replacement: Schritt 4, Bild 2 von 2
    • Use plastic opening tool to remove the bottom white cover as shown.
  5. Sony Xperia Sola Speaker Replacement: Schritt 5, Bild 1 von 2 Sony Xperia Sola Speaker Replacement: Schritt 5, Bild 2 von 2
    • There are two additional screws under the bottom white cover as shown.
    • Use T3 drivers to remove two additional screws as shown.
  6. Sony Xperia Sola Speaker Replacement: Schritt 6, Bild 1 von 3 Sony Xperia Sola Speaker Replacement: Schritt 6, Bild 2 von 3 Sony Xperia Sola Speaker Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Using plastic opening tool, lift to remove the small black cover on the bottom left of phone as shown.
    • Then, using tweezers to lift the connector straight up to disconnect the battery's circuit as shown.
  7. Sony Xperia Sola Speaker Replacement: Schritt 7, Bild 1 von 3 Sony Xperia Sola Speaker Replacement: Schritt 7, Bild 2 von 3 Sony Xperia Sola Speaker Replacement: Schritt 7, Bild 3 von 3
    • Turn the phone onto its side and insert a flat object and gently remove cover, using plastic opening tool as shown.
  8. Sony Xperia Sola Speaker Replacement: Schritt 8, Bild 1 von 3 Sony Xperia Sola Speaker Replacement: Schritt 8, Bild 2 von 3 Sony Xperia Sola Speaker Replacement: Schritt 8, Bild 3 von 3
    • Flip over the black back cover and locate the speaker phone at the bottom, then use the tweezers to remove the speaker. It is glued to the back cover so a little force will be needed.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Bo Wu
292 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S5-G3, Lacy Spring 2017 Mitglied von USF Tampa, Team S5-G3, Lacy Spring 2017
USFT-LACY-S17S5G3
3 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 17
Insgesamt: 491
