Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide can help you remove the front facing camera.
  1. Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  5. To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture. To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  6. Using the tweezer, carefully pry open the chip for the front facing camera as shown. Then using the tweezer, carefully remove the front facing camera component.
    • Using the tweezer, carefully pry open the chip for the front facing camera as shown. Then using the tweezer, carefully remove the front facing camera component.
Abschluss
8 weitere Nutzer haben diese Anleitung absolviert.
Christina Wojaczyk
1.429 Reputation
7 Anleitungen geschrieben
USF Tampa, Team 13-3, Staggers Fall 2014 Mitglied von USF Tampa, Team 13-3, Staggers Fall 2014
USFT-STAGGERS-F14S13G3
3 Mitglieder
From camera icon is not available
rameshmax - Antwort
Front camera is not available
rameshmax - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 3,779
