Zum Hauptinhalt wechseln
Sony Xperia T2 Ultra Dual Motherboard Replacement
Was du brauchst
  1. Sony Xperia T2 Ultra Dual Motherboard Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Motherboard Replacement, Removing the internal cover: Schritt 3, Bild 1 von 1
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Motherboard Replacement: Schritt 4, Bild 1 von 2 Sony Xperia T2 Ultra Dual Motherboard Replacement: Schritt 4, Bild 2 von 2
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Motherboard Replacement, Removing Chip: Schritt 5, Bild 1 von 1
    • To take out the back facing camera, flip open the flap labelled ‘film’ to reveal the chip that connects to the motherboard.
  6. Sony Xperia T2 Ultra Dual Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Use the tweezer, carefully pry open the chip for the back facing camera.
  7. Sony Xperia T2 Ultra Dual Motherboard Replacement, Remove back facing camera: Schritt 7, Bild 1 von 1
    • Then using the tweezer, carefully remove the back facing camera component.
  8. Sony Xperia T2 Ultra Dual Motherboard Replacement, Removing the Front Camera: Schritt 8, Bild 1 von 1
    • Using the tweezer, carefully pry open the chip for the front facing camera as shown. Then using the tweezer, carefully remove the front facing camera component.
  9. Sony Xperia T2 Ultra Dual Motherboard Replacement, Removing chip: Schritt 9, Bild 1 von 1
    • Using tweezer, locate the audio jack as shown and pull out the chip connected to the motherboard.
  10. Sony Xperia T2 Ultra Dual Motherboard Replacement, Remove audio jack: Schritt 10, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Carefully remove the audio jack by using the tweezers and pull firmly straight out of the motherboard.
  11. Sony Xperia T2 Ultra Dual Motherboard Replacement, Motherboard: Schritt 11, Bild 1 von 2 Sony Xperia T2 Ultra Dual Motherboard Replacement, Motherboard: Schritt 11, Bild 2 von 2
    • Using tweezers, locate the battery connector and carefully pull up to disconnect it.
  12. Sony Xperia T2 Ultra Dual Motherboard Replacement: Schritt 12, Bild 1 von 2 Sony Xperia T2 Ultra Dual Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Carefully remove the button circuit connector by using tweezers and gently pulling up.
  13. Sony Xperia T2 Ultra Dual Motherboard Replacement: Schritt 13, Bild 1 von 2 Sony Xperia T2 Ultra Dual Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Carefully remove the silver plug by using the tweezers to lift straight up.
  14. Sony Xperia T2 Ultra Dual Motherboard Replacement: Schritt 14, Bild 1 von 2 Sony Xperia T2 Ultra Dual Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Carefully remove the SIM card connector using tweezers by gently pulling it straight up.
  15. Sony Xperia T2 Ultra Dual Motherboard Replacement: Schritt 15, Bild 1 von 2 Sony Xperia T2 Ultra Dual Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Using tweezers, carefully remove the motherboard by pulling it up and out of the backing.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
IUPUI, Team S1-G3, Harley Spring 2017 Mitglied von IUPUI, Team S1-G3, Harley Spring 2017
IUPUI-HARLEY-S17S1G3
4 Mitglieder
3 Anleitungen geschrieben
2 Kommentare zur Anleitung
Mayrka D5322 ke bad cahiy
Goving Ram Goving Ram - Antwort Teilen
I have a sony xperia dual ultra T2
RAM 1GB ITS REALLY POOR FOR THE TAB
HOW CAN I CHANGE THE RAM.
ANS ME PLEASE
MP - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 3,966
