Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This guide can be used to remove the back camera.
  1. Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture. To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  6. To take out the back facing camera, flip open the flap labelled ‘film’ to reveal the chip that connects to the motherboard.
    • To take out the back facing camera, flip open the flap labelled ‘film’ to reveal the chip that connects to the motherboard.
  7. Use the tweezer, carefully pry open the chip for the back facing camera.
    • Use the tweezer, carefully pry open the chip for the back facing camera.
  8. Then using the tweezer, carefully remove the back facing camera component.
    • Then using the tweezer, carefully remove the back facing camera component.
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
Christina Wojaczyk
1.429 Reputation
7 Anleitungen geschrieben
USF Tampa, Team 13-3, Staggers Fall 2014 Mitglied von USF Tampa, Team 13-3, Staggers Fall 2014
USFT-STAGGERS-F14S13G3
3 Mitglieder
Hlo hi sir Sony back cam of Sony Xperia t2 ultra
sai kiran - Antwort
Hi, Sir T2 Ultra dual Camera shows error - Unfortunately, Camera has stopped working. pls help . Thank yo
Alan Mathew - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 13
Insgesamt: 3,986
