Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide can be used to replace the speaker on your phone.
  1. Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  5. To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture. To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  6. Using the tweezer, pull out the speaker located on the inside of the back cover of the phone.
    • Using the tweezer, pull out the speaker located on the inside of the back cover of the phone.
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
Christina Wojaczyk
1.429 Reputation
7 Anleitungen geschrieben
USF Tampa, Team 13-3, Staggers Fall 2014 Mitglied von USF Tampa, Team 13-3, Staggers Fall 2014
USFT-STAGGERS-F14S13G3
3 Mitglieder
How to repair loudspeaker of t2 ultra
Azizah - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 2
Letzten 7 Tage: 3
Letzten 30 Tage: 7
Insgesamt: 9,263
