Zum Hauptinhalt wechseln
Sony Xperia TL Display Assembly Replacement
Was du brauchst
  1. Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: Schritt 1, Bild 1 von 3 Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: Schritt 1, Bild 2 von 3 Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: Schritt 1, Bild 3 von 3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: Schritt 2, Bild 1 von 2 Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: Schritt 3, Bild 1 von 3 Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: Schritt 3, Bild 2 von 3 Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: Schritt 3, Bild 3 von 3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Display Assembly Replacement, Loud Speaker: Schritt 4, Bild 1 von 3 Sony Xperia TL Display Assembly Replacement, Loud Speaker: Schritt 4, Bild 2 von 3 Sony Xperia TL Display Assembly Replacement, Loud Speaker: Schritt 4, Bild 3 von 3
    • Use the plastic opening tool to remove the loud speaker module.
  5. Sony Xperia TL Display Assembly Replacement, Battery: Schritt 5, Bild 1 von 3 Sony Xperia TL Display Assembly Replacement, Battery: Schritt 5, Bild 2 von 3 Sony Xperia TL Display Assembly Replacement, Battery: Schritt 5, Bild 3 von 3
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  6. Sony Xperia TL Display Assembly Replacement, Battery Harness: Schritt 6, Bild 1 von 3 Sony Xperia TL Display Assembly Replacement, Battery Harness: Schritt 6, Bild 2 von 3 Sony Xperia TL Display Assembly Replacement, Battery Harness: Schritt 6, Bild 3 von 3
    • Unhook the 2 connections between the harness and phone shell.
    • Using the plastic opening tool, pry the harness up and remove it.
    • There is an adhesive on the bottom half of the battery harness.
  7. Sony Xperia TL Display Assembly Replacement: Schritt 7, Bild 1 von 1
    • The final step is taking the entire harness off of the phone.
  8. Sony Xperia TL Display Assembly Replacement, Motherboard: Schritt 8, Bild 1 von 3 Sony Xperia TL Display Assembly Replacement, Motherboard: Schritt 8, Bild 2 von 3 Sony Xperia TL Display Assembly Replacement, Motherboard: Schritt 8, Bild 3 von 3
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
  9. Sony Xperia TL Display Assembly Replacement, Ear Speaker: Schritt 9, Bild 1 von 1
    • Use the plastic opening tool to detach the ear piece speaker.
    • Avoid majorly bending the tiny metal hooks holding the ear piece in.
  10. Sony Xperia TL Display Assembly Replacement, Display Assembly: Schritt 10, Bild 1 von 1
    • Once every single piece is removed from the main screen/digitizer this will be the only remaining piece. Nothing else can be removed. If you need to replace your screen this entire piece must be replaced.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Adam Giniger
1.303 Reputation
8 Anleitungen geschrieben
USF Tampa, Team 4-4, Brown Fall 2014 Mitglied von USF Tampa, Team 4-4, Brown Fall 2014
USFT-BROWN-F14S4G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 539
