Zum Hauptinhalt wechseln
Sony Xperia Tablet Z Battery Replacement
Was du brauchst
  1. Sony Xperia Tablet Z Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Sony Xperia Tablet Z Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the plastic removal tool in the corner of the object.
    • Slide the plastic removal tool along the edges.
  2. Sony Xperia Tablet Z Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the cover
    • Disconnect the battery, to avoid electric shock, by pulling up on the white plastic shown with the orange box.
  3. Sony Xperia Tablet Z Battery Replacement: Schritt 3, Bild 1 von 3 Sony Xperia Tablet Z Battery Replacement: Schritt 3, Bild 2 von 3 Sony Xperia Tablet Z Battery Replacement: Schritt 3, Bild 3 von 3
    • In the top right corner of the device remove the piece of tape connecting the front camera to the motherboard.
    • Then disconnect the camera from the motherboard.
    • Lift and remove the front camera to expose hidden screw to replace battery.
  4. Sony Xperia Tablet Z Battery Replacement: Schritt 4, Bild 1 von 3 Sony Xperia Tablet Z Battery Replacement: Schritt 4, Bild 2 von 3 Sony Xperia Tablet Z Battery Replacement: Schritt 4, Bild 3 von 3
    • Remove all screws connecting the battery to the tablet. Location of screws shown with red circles.
    • Then lift the left side first then detach the connection in the lower right corner. Connection shown with orange box.
    • Completely remove the battery.
Abschluss
26 weitere Personen haben diese Anleitung absolviert.
Martin Luna
1.873 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 15-6, Remmell Fall 2014 Mitglied von USF Tampa, Team 15-6, Remmell Fall 2014
USFT-REMMELL-F14S15G6
3 Mitglieder
7 Anleitungen geschrieben
14 Kommentare
Helps me with info I need for a screen replacement. I'll post pics when I complete it. need a new screen first, hard to find for that model.
evildrifty - Antwort
hi,
thanks for this tutorial. do you know where I can buy the tablet battery ? thanks for your help.
safae - Antwort
Same question. Where would be the best place to purchase a battery? All I've found seems sketchy and I dont want to have a time bomb on hand.
Gui L - Antwort
any one actially got any andswers about were to actually get this replacement battery.. WHY OH WHY do the tuitorial without mentiong were to find the fleeping replacement?????
AvoidSonyAllTogether - Antwort
Hello friends, for Sony Xperia Tablet Z 4 same way ?
thank you for support
Andi - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 21
Letzte 7 Tage: 65
Letzte 30 Tage: 166
Insgesamt: 45,041
