Zum Hauptinhalt wechseln
Sony Xperia U Headphone Jack Replacement
Was du brauchst
  1. Sony Xperia U Headphone Jack Replacement, Battery: Schritt 1, Bild 1 von 1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Headphone Jack Replacement, Headphone Jack: Schritt 3, Bild 1 von 1
    • Insert the plastic opening tool in between the white plastic cover, and the body of the phone.
    • Pop the plastic cover off. To do this, gently push forward on the plastic opening tool while it is in between the cover and the phone.
  4. Sony Xperia U Headphone Jack Replacement: Schritt 4, Bild 1 von 1
    • Remove the six size 0 Phillips screws.
  5. Sony Xperia U Headphone Jack Replacement: Schritt 5, Bild 1 von 1
    • Insert the plastic opening tool in between the body of the phone and the thin plastic back cover.
    • Lift the black back cover off of the body with the plastic tool.
  6. Sony Xperia U Headphone Jack Replacement: Schritt 6, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Locate the earphone jack on the top left of the black plastic back cover.
    • Use the tweezers to pinch the earphone jack and remove it from the back cover.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Bader
545 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 7-2, Leahy Fall 2014 Mitglied von USF Tampa, Team 7-2, Leahy Fall 2014
USFT-LEAHY-F14S7G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 40
Insgesamt: 1,366
