Zum Hauptinhalt wechseln
Sony Xperia X Battery Replacement
Was du brauchst
Videoanleitungen
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Witrigs
69.454 Reputation
378 Anleitungen geschrieben
2 Kommentare
From my experience with Sony Xperia Z2 you do not need any adhesive on the new battery,it stays in place by the other components.
Claes - Antwort
You dont need new adhesive for the new battery just as Claes said. The battery adhesive tab broke on me so I had to scrape the battery and the adhesive apart. Its soo much pain and risk puncturing the old battery. You can also try reusing the old back cover adhesive. If you dont remove the old back cover adhesive then you’ll stack the old adhesive and the new one so the back cover doesnt sit flush anymore. Which isnt really a problem.
afiqz97 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 34
Insgesamt: 21,111
