Zum Hauptinhalt wechseln
Einleitung
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
  1. Sony Xperia XA Back Camera Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Back Camera Replacement: Schritt 2, Bild 1 von 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Back Camera Replacement: Schritt 3, Bild 1 von 3 Sony Xperia XA Back Camera Replacement: Schritt 3, Bild 2 von 3 Sony Xperia XA Back Camera Replacement: Schritt 3, Bild 3 von 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Back Camera Replacement: Schritt 4, Bild 1 von 3 Sony Xperia XA Back Camera Replacement: Schritt 4, Bild 2 von 3 Sony Xperia XA Back Camera Replacement: Schritt 4, Bild 3 von 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Back Camera Replacement: Schritt 5, Bild 1 von 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Back Camera Replacement: Schritt 6, Bild 1 von 1
    • Peel back the RAF antenna.
  7. Sony Xperia XA Back Camera Replacement, Motherboard: Schritt 7, Bild 1 von 2 Sony Xperia XA Back Camera Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Pry up the copper connector next to the battery with the plastic opening tool.
  8. Sony Xperia XA Back Camera Replacement: Schritt 8, Bild 1 von 2 Sony Xperia XA Back Camera Replacement: Schritt 8, Bild 2 von 2
    • Remove the five black 4mm screws with a Phillips #00 Screwdriver.
  9. Sony Xperia XA Back Camera Replacement: Schritt 9, Bild 1 von 3 Sony Xperia XA Back Camera Replacement: Schritt 9, Bild 2 von 3 Sony Xperia XA Back Camera Replacement: Schritt 9, Bild 3 von 3
    • Pry up the black camera case with the plastic opening tool and then remove the case.
  10. Sony Xperia XA Back Camera Replacement: Schritt 10, Bild 1 von 2 Sony Xperia XA Back Camera Replacement: Schritt 10, Bild 2 von 2
    • Pop off the small connector on the right side of the motherboard with the plastic opening tool.
  11. Sony Xperia XA Back Camera Replacement: Schritt 11, Bild 1 von 2 Sony Xperia XA Back Camera Replacement: Schritt 11, Bild 2 von 2
    • Use the spudger to take off the connector in the top right of the motherboard.
  12. Sony Xperia XA Back Camera Replacement: Schritt 12, Bild 1 von 3 Sony Xperia XA Back Camera Replacement: Schritt 12, Bild 2 von 3 Sony Xperia XA Back Camera Replacement: Schritt 12, Bild 3 von 3
    • Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
    • Peel back the tab past the connector.
    • Tab is stuck with adhesive.
  13. Sony Xperia XA Back Camera Replacement: Schritt 13, Bild 1 von 3 Sony Xperia XA Back Camera Replacement: Schritt 13, Bild 2 von 3 Sony Xperia XA Back Camera Replacement: Schritt 13, Bild 3 von 3
    • Pry up the camera's connector to the motherboard with the nylon spudger.
  14. Sony Xperia XA Back Camera Replacement: Schritt 14, Bild 1 von 2 Sony Xperia XA Back Camera Replacement: Schritt 14, Bild 2 von 2
    • Use the spudger to loosen the black connector from the top right of the motherboard.
  15. Sony Xperia XA Back Camera Replacement: Schritt 15, Bild 1 von 3 Sony Xperia XA Back Camera Replacement: Schritt 15, Bild 2 von 3 Sony Xperia XA Back Camera Replacement: Schritt 15, Bild 3 von 3
    • Pull out the square shaped connector using tweezers.
  16. Sony Xperia XA Back Camera Replacement: Schritt 16, Bild 1 von 2 Sony Xperia XA Back Camera Replacement: Schritt 16, Bild 2 von 2
    • Use the spudger to detach the three copper connectors on the bottom area of the motherboard.
  17. Sony Xperia XA Back Camera Replacement: Schritt 17, Bild 1 von 3 Sony Xperia XA Back Camera Replacement: Schritt 17, Bild 2 von 3 Sony Xperia XA Back Camera Replacement: Schritt 17, Bild 3 von 3
    • Use the spudger to separate the motherboard from the frame.
    • Pull out the motherboard using your fingers.
  18. Sony Xperia XA Back Camera Replacement, Back Camera: Schritt 18, Bild 1 von 2 Sony Xperia XA Back Camera Replacement, Back Camera: Schritt 18, Bild 2 von 2
    • Use the nylon spudger to pry up the black camera connector from the motherboard.
    • The connector is attached with adhesive.
  19. Sony Xperia XA Back Camera Replacement: Schritt 19, Bild 1 von 1
    • Use your fingers to gently pull the camera off the motherboard.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Cal Poly, Team S17-G2, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 6
Insgesamt: 710
