Einleitung
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
Ersatzteile
Keine Ersatzteile angegeben.
Stick the small suction cup on the bottom half of the back surface of the phone.
With the bottom of the device facing you, lift up on the suction cup handle.
Use the plastic opening tool around all sides to pry off the back cover.
Fast fertig!
Abschluss
