Zum Hauptinhalt wechseln
Einleitung
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
  1. Apply heat  on the back surface of the phone.
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Stick the small suction cup on the bottom half of the back surface of the phone.
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. With the bottom of the device facing you, lift up on the suction cup handle. Use the plastic opening tool around all sides to pry off the back cover. Use the plastic opening tool around all sides to pry off the back cover.
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Pull the back of the phone case away from the device. You will hear popping sounds of glue being ripped from the phone. You will hear the sound of the back unlatching from the device.
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Apply heat to the copper RAF antenna.
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Peel back the RAF antenna.
    • Peel back the RAF antenna.
  7. Peel back the black tabs on the battery. This may require some force as you are breaking the adhesive seal. You will need to apply more adhesive for the reassembly.
    • Peel back the black tabs on the battery.
    • This may require some force as you are breaking the adhesive seal.
    • You will need to apply more adhesive for the reassembly.
  8. Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone. Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
    • Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
  9. Use a plastic opening tool to get under the battery and pry it up.
    • Use a plastic opening tool to get under the battery and pry it up.
  10. Lift the battery out with your hands.
    • Lift the battery out with your hands.
  11. Remove the four 4mm screws holding the loudspeaker in place with a Phillips #00 screwdriver. Remove the four 4mm screws holding the loudspeaker in place with a Phillips #00 screwdriver.
    • Remove the four 4mm screws holding the loudspeaker in place with a Phillips #00 screwdriver.
  12. Push back the two retaining tabs on the top of the loudspeaker with the spudger. Push back the two retaining tabs on the top of the loudspeaker with the spudger.
    • Push back the two retaining tabs on the top of the loudspeaker with the spudger.
  13. Pry the loudspeaker up with the spudger.
    • Pry the loudspeaker up with the spudger.
  14. Remove the loudspeaker with your hands.
    • Remove the loudspeaker with your hands.
  15. With a spudger, pry up the orange connector that is directly underneath where the loud speaker was just removed.
    • With a spudger, pry up the orange connector that is directly underneath where the loud speaker was just removed.
  16. Pry up the small silver connector on the right side of the bottom of the phone with a spudger. Pry up the small silver connector on the right side of the bottom of the phone with a spudger.
    • Pry up the small silver connector on the right side of the bottom of the phone with a spudger.
  17. Pry up the charging port using a spudger. Pry up the charging port using a spudger.
    • Pry up the charging port using a spudger.
  18. Remove the five black 4mm screws with a Phillips #00 screwdriver. Remove the five black 4mm screws with a Phillips #00 screwdriver.
    • Remove the five black 4mm screws with a Phillips #00 screwdriver.
  19. Pry up the black camera case with a nylon spudger, and then remove the case.
    • Pry up the black camera case with a nylon spudger, and then remove the case.
  20. Use a spudger to pry up the six motherboard connectors. Use a spudger to pry up the six motherboard connectors. Use a spudger to pry up the six motherboard connectors.
    • Use a spudger to pry up the six motherboard connectors.
  21. Use the flat end of the nylon spudger to lift the camera out of the phone.
    • Use the flat end of the nylon spudger to lift the camera out of the phone.
  22. Pull out the front camera using your fingers.
    • Pull out the front camera using your fingers.
  23. Use the spudger to separate the motherboard from the frame.
    • Use the spudger to separate the motherboard from the frame.
  24. Pry up the headphone jack using a spudger. Pry up the headphone jack using a spudger.
    • Pry up the headphone jack using a spudger.
  25. Peel back the black tabs that were holding the battery in place. You may hear loud sounds as you pull the tabs because they are stuck with adhesive.
    • Peel back the black tabs that were holding the battery in place.
    • You may hear loud sounds as you pull the tabs because they are stuck with adhesive.
  26. Remove the two 4 mm screws with a Phillips #000 screwdriver from the left side of the back of the screen. Remove the two 4 mm screws with a Phillips #000 screwdriver from the left side of the back of the screen.
    • Remove the two 4 mm screws with a Phillips #000 screwdriver from the left side of the back of the screen.
  27. Remove the three 3mm screws with a T5 screwdriver along the side of the device where the volume buttons are. Remove the three 3mm screws with a T5 screwdriver along the side of the device where the volume buttons are.
    • Remove the three 3mm screws with a T5 screwdriver along the side of the device where the volume buttons are.
  28. Push down the side of the screen that you just removed screws from. Push down the side of the screen that you just removed screws from.
    • Push down the side of the screen that you just removed screws from.
  29. Pull up the orange and black tab that is on the left half of the middle of the screen. Pull up the orange and black tab that is on the left half of the middle of the screen. Pull up the orange and black tab that is on the left half of the middle of the screen.
    • Pull up the orange and black tab that is on the left half of the middle of the screen.
  30. Remove the Wifi antenna. Remove the Wifi antenna.
    • Remove the Wifi antenna.
  31. Remove the three 3 mm screws with a Star Bit T5 Screwdriver on the opposite side of the phone. Remove the three 3 mm screws with a Star Bit T5 Screwdriver on the opposite side of the phone.
    • Remove the three 3 mm screws with a Star Bit T5 Screwdriver on the opposite side of the phone.
  32. Use tweezers to remove the earpiece. Use tweezers to remove the earpiece.
    • Use tweezers to remove the earpiece.
Abschluss
6 weitere Nutzer haben diese Anleitung absolviert.
Cal Poly, Team S17-G2, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 3
Letzten 7 Tage: 16
Letzten 30 Tage: 75
Insgesamt: 3,454
