Einleitung
This is a prerequisite guide for taking the back cover off of the Sony Xperia XA1. All of the repairs require you to remove the back of the phone, and this guide shows how to safely remove the back cover of the phone.
Was du brauchst
Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
