Einleitung
This guide will show you how to remove the antenna module from your Sony Xperia XA1 Ultra. The antenna module will need to be removed to access other parts of the phone or replaced if the phone experiences connectivity issues. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. In addition, a T5 screwdriver is needed to remove screws and a spudger is used to lift up components of the phone.
Was du brauchst
Wedge your finger under the bottom ridge of the SD card insert.
Pull outwards with your fingers to remove the SD card from the left side of device.
Use a hair dryer to heat each corner of the phone.
Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
Press a suction cup on a heated corner of the device.
Hold the phone down and gently lift the suction cup to create a small gap.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
Slide your plastic card along the side of your phone to loosen the adhesive.
Move the card along the sides of the phone to lift all of the corners.
Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
Insert your iFixit Opening Tool underneath the antenna module.
Lift up gently with the iFixit Opening Tool to remove the antenna module.
Eine weitere Person hat diese Anleitung absolviert.
