Zum Hauptinhalt wechseln
Sony Xperia XA1 Ultra Loudspeaker Replacement
Was du brauchst
  1. Sony Xperia XA1 Ultra Loudspeaker Replacement, Back Assembly: Schritt 1, Bild 1 von 2 Sony Xperia XA1 Ultra Loudspeaker Replacement, Back Assembly: Schritt 1, Bild 2 von 2
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
  2. Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 2, Bild 1 von 1
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
  3. Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 3, Bild 1 von 1
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
  4. Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 4, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
  5. Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 5, Bild 1 von 1
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
  6. Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 6, Bild 1 von 1
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
  7. Sony Xperia XA1 Ultra Loudspeaker Replacement, Loudspeaker: Schritt 7, Bild 1 von 1
    • Remove the five 4mm T5 screws connecting the speaker to your phone.
  8. Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 8, Bild 1 von 2 Sony Xperia XA1 Ultra Loudspeaker Replacement: Schritt 8, Bild 2 von 2
    • Insert your iFixit Opening Tool underneath the speaker and gently lift up.
    • Once the speaker is slightly lifted, use your hands to remove the piece from the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Jacob Jung
1.429 Reputation
9 Anleitungen geschrieben
Cal Poly, Team S16-G3, Livingston Spring 2018 Mitglied von Cal Poly, Team S16-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G3
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 29
Insgesamt: 1,017
